.. # Copyright (c) 2021-2022, Arm Limited. # # SPDX-License-Identifier: MIT ################### Codeline Management ################### The EWAOL project is released and developed based on Yocto's release branch process. This strategy allows us to make Major, Minor and Point/Patch Releases based on upstream stable branches, reducing the risk of having build and runtime issues. ****************************** Yocto Release Process Overview ****************************** | .. image:: images/ewaol_rel_yocto_overview.png :align: center | The diagram above gives an overview of the Yocto branch and release process: * |inclusivity-exception| Development happens primarily in the master (or main) branch. * The project has a major release roughly every 6 months where a stable release branch is created. * Each major release has a `codename` which is also used to name the stable release branch (e.g. kirkstone). * Once a stable branch is created and released, it only receives bug fixes with minor (point) releases on an unscheduled basis. * The goal is for users and 3rd parties layers to use these codenamed branches as a means to be compatible with each other. For a complete description of the Yocto release process, support schedule and other details, see the |Yocto Release Process|_ documentation. ******************************** EWAOL Branch and Release Process ******************************** | .. image:: images/ewaol_rel_dev_branches.png :align: center | EWAOL's branch and release process is based on the Yocto release process. The following sub-sections describe in more details the branch strategy for EWAOL's development and release process. EWAOL main branch ================= * Represented by the green line on the diagram above. * The repository's ``main`` branch is meant to be compatible with |inclusivity-exception| ``master`` or ``main`` branches from Poky and 3rd party layers. * ``meta-ewaol`` is not actively developed on this ``main`` branch to avoid the instability inherited from Yocto development on the |inclusivity-exception| master branch. * To reduce the effort required to move EWAOL to a new version of Yocto, this main branch is periodically updated with patches from the `EWAOL development branches`_ on a regular basis. EWAOL development branches ========================== * Represented by the red line on the diagram above. * EWAOL uses development branches based/compatible with Yocto stable branches. * A development branch in EWAOL is setup for each new Yocto release using the name convention ``-dev`` where `` comes from target Yocto release. * The development branches in EWAOL are where fixes, improvements and new features are developed. * On a regular basis, code from the development branch is ported over to the ``main`` branch to reduce the effort required to move EWAOL to a new version of Yocto. EWAOL release branches ====================== * Represented by the blue line on the diagram above. * A new release branch in EWAOL is setup for each new Yocto release using the Yocto `codename` the branch targets. * Hot fixes in the release branch are back ported to the development branch. * Release branches are currently maintained not much longer than a Yocto release period (~7 months). EWAOL release tags ================== * EWAOL is tagged using the version format ``v..``. * Tags are always applied to commits from the release branch. * The first release in a release branch is a `Major` release. * Following releases in a release branch advance the `Minor` version number. * `Patch` releases are mainly used for hot fixes which are then back ported to the development branch. * Both `Major` and `Minor` releases may receive fixes, improvements and new features while `Patch` releases only receive fixes. Poky and 3rd party layers release/stable branches might be updated and pinned.
